It could be injector cups, but being an lly.. Most llikely head gaskets Try looking around the egr see if you see any coolant stains from it being cracked. Is it eating coolant?
Injector cups on a lly???? They dont have cups
He said it isn't using water just pressuring up the coolant tank . He also said a gm mechanic told him how to test for a head gasket and it tested good . I can't tell you how he tested it cause i was losing signal . It does have a little discoloration in the tank .
