LLY: pressure limit for stock FPRV?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I can't say exactly but before I shimmed mine, 100 horse tune would pop mine every time. I'm sure my spring was weak to begin with. I shimmed it and have since never once popped it even with dual cp3's and holding 26100 psi.
thunder550
1,176
Phoenix, AZ
Ok. I'm chasing a surging issue with the truck, whenever the power cuts out the fuel pressure spikes to almost 26k, and occasionally drops to 10k after. My theory was that the FPRV was opening sometimes when the pressure spikes. Sounds like that's a plausible explanation.
9,903
149
X2. Do a bottle test.
Or just shim it as you should anyways and see what happens.
thunder550
1,176
Phoenix, AZ
Shim would probably be good. Does the LBZ FPRV fit the LLY? It's going to be a little bit before I can do this, I think I lost the HGs again yesterday doing some testing. Can't wait to do that job again. :nana3:
