We need more info on the truck broski. My Lb7 in the 40,000 mike I had it in my truck I was always able to squeeze the rad hose even after a two hundred mile non stop run. SOME pressure is normal and should receded over night.
Are you loosing coolant? Puking out the overflow tube? Some would say replace the radiator cap before doing anything else they pop off @ 16 psi. If your seeing that kind of pressure you MAY or MAY NOT have a head gasket issue
