Press fit gauge mount to metal plate mount question.
ripmf666
15,123
14
47
Wentzville Mo
Dave on the back side of your gauges do you have 2 studs coming out? If so you should be able to order a mounting kit like autometer sells with there gauges that holds them in tight from the back side.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
There is 2 plastic studs but they don't look like they are threaded and I can't seem to find anything online. I did buy them from Chad, I guess I'll just ask him. Thanks.
jlawles2
1,066
Danbury, TX
For my ISSPRO gauges to fit like I wanted them, I wrapped electrical tape around it to snug it up in the hole (trim around the lock tabs), then took an o-ring and put it behind the face and under the tabs. The tape made the gauge not move around, and the o-ring made the tabs hold. I can get you a picture if needed.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Thanks for the idea, I think I'll try that. I did find a mounting kit from Isspro R19999 but I can't find anyone who sells them.
jlawles2
1,066
Danbury, TX
Just remembered. The o-ring is actually between the gauge bezel and the mount on the outside. What I ended up doing, was to assemble everything listed, then push it into the hole. The o-ring helps to keep the gauges from rotating. I found that my gauges would turn slightly over time until I installed the o-ring.
For the mounting kit, talk to Chad, if he sold you the gauges, he can get the kit.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I tried putting 2 rounds of electrical tape around the gauge and they fit very snug now. I don't think I will even bother buying the mounting hardware. Thanks for the tip.
