Predictions for power and e/t ?
xcablb7
Feb 8, 2009
536
Fall River
Not much left to the season but should be able to get to the track once or twice with the setup.
04 lb7 ecsb 6700-6800 lbs
4088r with 4718, turbonetics 50mm w/g on 4088r
custom ground cam for twins (dont have cam card on me i'll post it up later)
16.5:1, dual fuelers with lbz pumps, stock injectors for now
anyone run a similar setup and have dyno numbers ?
1,802
stock motor: one run, maybe two, then boom.
built motor: mid/high 10s
Id ask Trent, Rob or Nathan what they think.
tysmith
ZF-6
Aug 29, 2008
35
Not sure, but I'm guessing one hook on the track, a couple passes at the strip, and that trans is going to need refreshing! But that week you'll get to drive it in between should be a blast! :hug:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I will break my guess up in ET and MPH , because with out knowing how spot on the tuning will be , suspension setup , traction , ect all these things become real important as the power goes up . My guess assuming the tuning is optimum would be.
mph in the 120-127 range
ET in the 10.8 - 11.5 range .
I dont guess at dyno #'s , pretty much worthless regardless of what the #
The turbo combo with the right supporting mods should be good for 900 hp , maybe 1k but she will be good and hot and drive pressure will be high with the 4718 at that power , but would probably make it .
xcablb7
Feb 8, 2009
536
Fall River
thanks guys, it is a built motor so it should last a few passes lol, curious to see what it's going to take for tuning, the stock motor with stock single cp3 and a5k i managed to make 626 on dunbar's dyno. wonder how different this setup will be ??
paint94979
Beer Nazi
Sep 18, 2006
11,715
If i was you and the funds allowed it, i would get some bigger injectors pronto.
TrentNell
Jul 7, 2008
7,543
slc tuah
funds aren't allowing lol, they will have to wait budget is beyond blown thank god i got some of the deals that i did
I assumed you had bigger injectors . new guess 115-118 mph 11.5-12.0 range
unless you go crazy wild with the PW
TrentNell
Jul 7, 2008
7,543
slc tuah
so dual fuelers and twins you think it will only pick up 5 mph ? i went 110 with 590 h.p.
cant say , if you had injectors you would have the fuel to take advantage of the extra air , dual cp3's and stock stick is more fuel , but nothing compared to what it usually takes to put a truck in the 120+ mph range. wish you luck either way and would rather see your truck run better that my guess and be wrong so :)
xcablb7
Feb 8, 2009
536
Fall River
thanks trent, i'll only be able to make a couple passes if it goes faster than 11.5 anyway cuz i won't put a cage in this truck
13,639
679
I agree with all of the above. Those injectors are the limiting factor at this point. Last I checked, you can get your stock tips extrude honed for around $400.
xcablb7
Feb 8, 2009
536
Fall River
yeah but if im going to do them i want to do it once and do it right send out a set to be balanced and flow tested, i'm trying to do this all off my side job money. i only make 50k a year as a firefighter and still have my boat and bike, so when funds are low it means there almost out lol and i want this thing running next week, when i have the money i'll send out my spare set of injectors.
