LBZ: PPE Relearn
RandoTx
May 6, 2011
93
so my truck started then died after about 15 seconds last night. found my wif sensor dripping so figured out why it wont crank without the fuel/pressure. BUT before I saw that I went to change tunes from level 3 to 2 just to see if maybe was a tune problem....well buddy opened the door like an idiot after I told him not to during the tune process. froze the programmer so I had to go into diagnostics and use option "return truck to stock" my question is if I put level 3 tune back on will I have to do a tranny relearn? or does it just return the ECM back to stock without interfering with the tranny? hopefully I don't have to
do a relearn as it was starting to finally shift how I like it
3,733
305
It should only put the engine computer back to stock. I don't have a PPE programmer, but it doesn't make sense to automatically do a TAPS relearn when changing tunes without being told to.
Sent from my Galaxy Nexus using Tapatalk 2
werewolf
Apr 27, 2012
118
eastern Noth Carolina
From what I have read, PPE recommends any time changing a tune to do the trans relearn. But if you weren't planning on running it stock and going right back to the level 3 then I would't see a need to do it
jc1843
Sep 27, 2009
228
86
So Calf
Everytime I do a tune change, the trans always has to relearn. It does it with out resitting anything. It will shif different ans sometimes hard, until it relearns.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
I would leave mine alone when changing tunes. I had mine set on the 225/300 tune 99% of the time. If the power levels are close I would just leave it alone as I noticed nothing in the tranny from changing tunes..... But then again I have a badass :Dlbz
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
If you were on level 3 and went back to stock then back to level 3 and didn't drive on the stock level you wont need to reset the trans. Also theres no need to reset the trans when droping to a lower power level, only when going up.
