Question: PPE Duel fueler with A/C delete
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I just bought a PPE duel fueler. Will the cp3 mounting bracket work with an A/C delete pulley or do I need to fab up some kind of spacers? I'd like to just get rid of the A/C delete pulley all together if possible. It's going on an 02 LB7.
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Everyone I seen uses a spacer or cuts the ears off the AC pump.
I'm prob gonna delete the AC delete and just get a dif belt.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Just cut spacers out of some pipe either 3/8-1/2 and keep the same overall height as the compressor.
X2 on the spacers thats how i did mine at first , or you can remake the bracket .
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
One needs to be shorter if he is using the GM ac delete because it bolts in the same spot as the cp3
But I used washers, pipe and now cut the ears off the compressor
Whatever works right:)
Fwiw I deleted the pulley this year
Sledheadxp800r
Dec 13, 2010
1,151
CT
Does anyone know how tall the spacers need to be? The front bolt of the my a/c delete bracket is going to have to share the same hole.
Sledheadxp800r
Dec 13, 2010
1,151
CT
I guess I could measure the compressor mounts on my other truck :hmm: I don't why I didn't think of that
