Like Hondarider said, the 1/4 mile is the most accurate. How are you running 40% overs with an edge?New guy on this forum trying to get a idea on how to calculate estimated horse power from aftermarket bolt on parts
With 40% more fuel than the Edge thinks it is putting in... How are you running 40% overs with an edge?
It's called 1320'
:spit:
But really, a 40% injector is small enough you can probably get away with it if you leave the Edge on the lower levels.
Jesse, get yourself a good EFILive tune, and your truck will be a whole different animal.
And like everyone has said, the 1/4 mile speed is a much better indicator of actual horsepower than anything. A good dyno will give you an idea. But just looking at a combination of parts? No way to get a good guess.
Thanks for input some was helpful I have a bullydog triple pup stacked with my edge the bully is on extreme and edge on three. Feels like I'm not getting full potential out of fuel system would it be worth switching to efi live? Allot of money tied up in the two but it's been a slow low money process one upgrade at a time
Trans is not built that's next on the slow process of upgrades probably should before I switch to efi. I just got the pump and was thinking should have Ben little more power that's y the original question. So I will do quarter mile and look into trans and torque converter thanks
Your going to muck something up doing this.
I'd switch to efi live ASAP. Running the stacked edge and bully dog you'll be rebuilding your engine before anything else.
