So I've never really looked into installing a power driver seat into a cab that was not power seat. Is it possible, & how much bs will I have to go through to get it to work?
It is as simple as hooking up positive to the large gauge red wire and ground to the large gauge black wire in the 12?? ish pin harness under the seat. The other wires are part of the heat pads and memory seat function if it has them.
Easy day! Just did it. I have a wt truck and finally wanted some nice seats. Just hook power and ground up. Now I have crank windows, manual locks and a 6 way adjustable power seat.
Follow the wires from the pads, if they go into the module just cut and wire to them there, if not follow them to the main connector. there will be a total of 4 wires, 2 to the bottom pad and 2 to the back pad. The polarity doesn't matter to the heat pads.
If you wire them in series you will have low heat and in parallel you will have high heat. You can also just get aftermarket switches/controller to do the same.
