Had my drivers window switch stop working so I replaced the switch assembly which includes the power window button (mirror tilt not extend). Shortly after whenever you turn the key the drivers mirror will start moving by itself. Usually if you push the mirror adjust button it will stop but occasionally the mirror adjust button for that mirror doesn't work at all. If you turn the key with the door open and then turn it off the mirror adjust motor will just stay running, you have to shut the door and turn the key on and off again to get it to stop. My DIC decides to work randomly and when it does I confirm "curb view assist" is turned off.
I've checked the wiring and plugs in the door and have had it apart several times since and it continues to happen. Not the end of the world but it's mildly annoying especially since I have to back out of a long driveway every morning. Not sure if anyone has had something similar happen and if so were you able to fix it?
Thanks
Thanks
