Polaris RZR questions
vzfarms
89
near Dayton, Ohio
I have been looking at Polaris RZR's now, debating on what to get. A dealer near me has several.
1) used 2010 rzr 130hrs $8500
2) new 2011 rzr-s limited edition desert tan $13100 after rebates
3) new 2011 rzr red $11000
I drove them, I refused to drive the 900cc lol way too much money. Anyways, I do mostly trail riding and I like the s model a lot. Who here owns them and what can you suggest? I also have a friend who wants to sell me an 08 regular model for $7000
Pros/cons of each?
Also, how negotiable should dealers be on these.
13,712
773
Pros/cons of each?
I don't own one, but my dad does, and I have driven it quite a bit. His is a 2010 RZR-S. It has a 4000 lb Viper Max winch, Muzzys dual exhaust, J-Strong roof with radio, 30" Maxxis Zilla tires, SuperATV 1.5" offset front A-arms (in order to clear the tires with no lift), WickedBilt electronic power steering, and snorkels on the air box and belt intake and exhaust with all the vents run into the snorkels. The thing is a blast and will go anywhere. Tops out at about 60 on the speedo, and has plenty of pep to get moving on the trails. The power steering makes it a dream to drive on tight winding trails, and the tires give you enough clearance to go through deep mud or clear steep obstacles. It will hill climb like crazy. I have a blast every time I go out in it.
13,712
773
Some of the limited edition 2011s do have the Fox shocks. I'm not sure about the 2012s though.
rmallen30
861
15
hillsboro ohio
2012 they are bringing back fox shocks but the 12''s are hard to get at the moment 11''s the s models have a $300 rebate and the base models have a $500 rebate as far as wiggle room it depends on the dealer alot of dealers have b/s fees freight set up destination and delivery charges that if you call on phone is never brought up till your ready to pay for it if your from dayton pro polaris is ok competition acc is terrible i work at a polaris dealer and we have been out of rzr's for almost 1 month we do hane a used one a 09 le orange w 1070 miles but its $8499 for the money i would buy new
fast03
1,201
60
Rancho Cucamonga
I have a stock 08 model. 1600 miles on the clock all dune time with the throttle matted. still on stock belt and still runs flat out at 60mph flatland. yeah wish I had a little more travel at times, but I go everywhere the others go.
AdaMax
Nov 26, 2010
412
Caldwell , Oh
I have a 2011 rzr 4 they have awesome suspension . Definately go with the S .
The 2012 have a little thicker skid plate and have a bushing in passenger grab handle to keep it from rattling .
5,817
What you buy depends on what you do with it. Trail/forest riding is perfect for the reg rzr if you dont need the extra power and suspension
The 11 s did come with fox shocks but it was an option. You could get the cheaper setup for less out the door without the fox shocks. Personally, if you run the car hard and use that suspesion, the foxes dont last long. They need new fluid after a year or two and have bad shock fade if your drive hard. The 4 seaters come with 2.0 foxes which last longer and resist shock fade better. Out the gate, the foxes are better then the crappy ones
Personally i love my s. I ported and polished the head, had s&s tune it, put a clutch kit in, added elka shocks, and a race radio/in car talk system. Ive raced it in desert saction races and beat on it alot. Shes yet to fail on me and runs much better with a tune. Dont change the stock exhaust on the s though. Onlt the s&s will give ya some power but stock makes more than any other aftermarket no matter what they say. Jagged exteme is very good family friends of ours and are fullt sponsored my polaris to race them. They take some punishment.
vzfarms
89
near Dayton, Ohio
Damn, so good reviews all around? :D I'm still sitting on the fence about spending that kind of money. On the other hand, nothing fun is cheap. I'm leaning towards new because of the ease of financing / better rates. Plus I won't have to worry about the cost of fixing anything right away.
J Spruill
bringer of truth
Mar 30, 2008
770
i have an rzr 11. bought it mainly to pull soil samples with but do some play riding as well. i did install a bigger set of tires and needed a lift to keep them from scrubbing on hard turns. i installed and exhaust ,top,winshield,chip,ext and its loads of fun for work and play. had it up to about 60 with over 600lbs of riders in it....
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
RZR's are a blast!!
Don't get the original/basic suspension rzr, the S suspension is much better with or without fox shocks.
I understand that in some places you are limited by width and the narrow basic suspension may be the only option. That sucks but at least you still have an option.
2011's are available with or without fox shocks depending on if you want to cut costs. The fox's are worth the extra money unless you have other plans like elkas, etc. I'm not sure what they change for 2012 on shock options.
2011 rzr rear axles bars are were changed. They are even weaker than the past axles, twist off pretty easy right next to the CV joint. Easy fix, gorilla makes great axles. SuperATV has the Rhino axles which are better than stock but not even close to as stout as the Gorilla's. You probably never break the stock axles in the dunes but anywhere else and it's a good chance you will twist them off.
2008-2009 are notorious for blowing front diff's when you get them in a bind. Poor cage design that was updated in later models.
As far as motor building, those little 800 polaris motors just don't make HP compared to the V-twins like the 850 polaris, canam, kawasaki, etc. that are on the market. Might as well leave it stock. If you do cams, headwork, pistons, etc and you will sink a lot of money and still be lacking HP! I'm just not a fan of these motors for performance but they are reliable.
I have a guy that I race ATV's with who has a turbo RZR. It has a little GT14 turbo with an intercooler and seperate injector/controller. It's a beast. Much easier to make HP with the turbo than complete motor builds on these engines. Only thing is the stock head studs and stock crank will only take around 7psi boost (some more, some are less).
The 900 RZR is night and day different, if you hav the cash I would much rather see you drive away in one of those. The new 850 engine design has definitely raised the performance bar for Polaris.
You can always add power steering later, all of the RZR models are the same. SuperATV makes a bolt on kit for around $600 (I think). I won't own a SxS without power steering, just too convenient when you have a beer in your hand!!
On a side note:
The new Arctic Cat Wildcat SxS should be hitting the ground shortly. I know a couple of people who will have factory demo's to thrash and abuse to see if engineering did their part. Our clutch guy is getting one, he was a big push on the new clutch designs that will be offered from the factory by Arctic Cat.
http://www.wildcatforums.net/forum/.../137-17-new-arcticcat-wildcat-pics-enjoy.html
