po804 code
slc lly
hotrod diesel
Jan 12, 2010
5
today while pulling a nieghbors truck out of a snow drift the truck limped and set a p0804 dtc code im assuming its the tranny [ats st 3 with 14000 miles since installed] as its been acting up lately usually throwing a 0735 code during full throtlle 4-5 shifts my question is what is the 0804 code and is my trans in need of a rebuild already? what would be my best option for getting this looked at and resolved? does mike L do ats work?
Jul 31, 2009
76
Sacramento, CA
P0804-- 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction - I'm not sure what would cause this.
P0735-- Gear 5 Incorrect ratio - If I remeber correct this often time means you sliped your clutches.
slc lly
hotrod diesel
Jan 12, 2010
5
been doing some reading on atf and saw that aftermarket clutches do better with dex lll and ive been using royal purple max atf should i do a fluid change? i change the spin on every 6000 miles. as it sits now i cant drive my truck the way i want to so i need a resolution anybody got any ideas?
15,681
I don't believe that is a valid code for the Allison 1000. What are you reading codes with?
slc lly
hotrod diesel
Jan 12, 2010
5
So i need to hook it up to a tech-2 or would efi work? do i need to get the truck to limp or will it just know? sorry man dont no much at this point about the allison other than i paid alot for mine and it isnt handling the power im currently at. Its holding back all other plans for the truck.:(
Cougar281
1,820
259
St Louis, MO
EFILive will work. If the codes haven't been cleared, they should show up as history, even if the truck is operating normally right now.
