Po087 low fuel rail pressure.
zach_carver
Jan 27, 2013
57
NORTH GA
Ok question guys.. Buddys gotta 06 lbz. Built trans sc, ad165 lift pump and all that. Stock injectors stock turbo and dual fuelers. He has efi live but the original owner had it tuned. Now since he bought the truck its getting low fuel pressure codes on even the 2nd setting. Supposed to be a low hp tune. Any thoughts? Was wanting to hit the strip this weekend.
It also gets the code on the 5th setting. Any time the trucks under a slight load it throws the code but it doesnt limp or anything..
Were not real sure on anything being shimmed. All work was done by rpm and not sure what all they done when they installed dual cp3's. Kinda odd though cause hes drove it about a month before it started this. Were kinda thinking maybe filters on air dog maybe needing changed?? We dont know.. Thanks for any help.
rgullett83
1,607
Illinois
Start with filters and go from there. Return rate test may need performed. I have an 06 lbz in the shop with 60k on it stock with the exception of a programmer (unknown by myself or owner). Another shop diagnosed it as a faulty cp3, still sets code. All 8 injectors are returning to much fuel.
Sent from my GT-I9300
6,076
Start by changing filters...
id start with a bottle test. its free after all :D
