Most of the injector threads are four leaking injectors. What damage can a plugged injector cause? I've noticed a ticking sound under hard acceleration, but no smoking with one injector that is reading as high as +10.
In park the spec is + or - 4. I would try the ice pick trick, and if that doesn't work look into replacing it.
Injectors 2 and 7 have hard turns in the wiring before the plug. That causes the contacts inside to lose contact or have intermittent contact with the injectors sometimes. Ice picking them is where you literally shove an ice pick through the plastic connector in a certain spot to re-compress the connector contacts onto the injector contacts.What is the ice pick trick?
