LB7: PLEASE HELP ME i have no clue LB7
cottoneyejoe0555
Dec 14, 2012
3
ripley,ny
it all started the evening of the 26th the truck started and after 5 sec it quit but after pumping the primer on top of the fuel filter till i could not push is anymore the truck fired up and never missed a beat. now it did it again the morning and evening of the 27th whats going on with it. the truck has afe intake, and edge juiced with attitude please help
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Sounds like you either have a leak in the fuel system and its not holding vaccum or your fuel filter head needs to be rebuilt because its not holding its prime.
Fastorange
Jan 31, 2009
256
ohio
when was the last time you changed your fuel filter? is there a plastic type filter on it or a metal one... some places like napa sell a platic type that doesnt work so well
cottoneyejoe0555
Dec 14, 2012
3
ripley,ny
yea still plastic screw, and yea stupid me yea i used a napa plastic filter cuz i ran out of my steel baldwin filters, but the filter has been on the truck for 5000 miles
diesel53
Sep 16, 2010
907
AZ
we have an lbZ doing the same thing, but how could the filter head wear out over 8 filter changes? What is there to wear out? The pumper?
Could it be a weak cp3?
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
There are about five areas in the filter head that can leak air in when under the normal vacuum. A partially clogged up fuel filter will emphasize the air leaks as there will be more vacuum.
diesel53
Sep 16, 2010
907
AZ
How hard is it to rebuild or just do away with the factory head set-up? Seems like it maybe easier to get rid of it and run an airdog.
JDPlowboy
624
Rebuild kit http://www.merchant-automotive.com/deluxeduramaxfuelfilterheadrebuildkit.aspx
It's fairly easy. I've done one for a friend. Also Installed an air dog for another one to delete the factory setup for same problem Just un bolt factory filter and loop the inlet and outlet lines together with a hose. Air dog costs much more but if you could afford it it would be the easiest, plus your feeding your cp3 then instead of it sucking. And better filtration. That's just my opinion
2011 Ferd F-teenthousand
