hey guys,
i got the low coolant warning, and no drip on the ground so i thought it was in my oil meaning internal leak. let it sit overnight, rad hose still rock hard, and a ton of pressure in bottle.
so I got a head gasket leak! best part you ask??? im 300 Miles from home!
i drove 600 miles or so, and over the course of that 600 miles the coolant was entering the oil. i dont want to drive it anymore at the risk of ruining my crank bearings.
so, im doing this in a parking lot with a pretty large assortment of sockets and wrenches. and other hand tools(i will buy more) and i will be here for at least another week so im doing it here.
a few questions though.....
i dont have a power washer, so i cant wash it before hand. but how do i prevent dirt from entering the cylinder once the head is off? im just gonna tape it off with painters tape i think.
how do i clean the surface of block that meets the head? i dont want anything getting in the cylinder?
what do i inspect/look for on block and piston when it is off?(i have never pulled the head off anything)
when i finish this job, do i need to adjust the timing?(i hope not)
can a machine shop set valve last?(im thinking about doing .011 in case one is overtightened)
do i need to pinch off a fuel line, then run the truck dry of fuel before this job?(i might empty the fuel filter then not prime it, and let it run dry)
do i need any specialty tools for this job i should get? do i need a torque wrench larger then 150ft/lbs?
if you can answer one or all of these questions you would be of help! i am a college student and really cant afford to pay someone to do this, so might as well try it myself!
if any central PA guys wanna come give me a hand for 10 minutes, or a whole day i would really appreciate that. im down at Penn State for a summer class(only way i could get in $$$ wise) and am not home working making that $$$
thanks,
Hank
thanks,
Hank
