Pitting on top of Pistons
dmax02
105
Taunton MA
From what I have read it seems it's caused by coolant being in the cylinders. But I'm not sure If this piston is ok run or not .
SilveradoTwins02
Hopefully twins soon
Aug 5, 2014
194
Hanover PA
Thanks Brain. I Delipped and radiused these last night for Zach and then after cleaning this one up, I seen this pitting and showed him the picture. Wasn't sure exactly what caused it and asked him to post in on here for better knowledge on this issue...
Awenta
4,090
CT
More than likely. I wouldn't use it though. How's the head look?
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
So that pic is AFTER the cut?
Im a paranoid little gearhead...but I wouldn't use them:eek:
:spit:
Sorry about your luck:(
dmax02
105
Taunton MA
Yes that is after getting cut. I ended up just getting another piston. From what fingers has said in previous posts its from running it so long with bad head gaskets / leaking injector cups.
