How many miles were on it?
I dont like the cognito braces for a couple reasons.
1. they dont keep the idler/pitman arm from wearing out like advertised cause any truck with a decent amount of over factory power will cause them to flex and still allow the idler/pitman arm to wear out, even just lifted stock power trucks.
2. they hide a bad pitman/idler arm. if you lifted your RF tire and tried to check for wear like most people do (trying to turn the tire left or right and make the drag link twist up or down), the braces wont let you as you dont have the torque needed to make them flex. you have to remove them to check the idler/pitman arm or put your tire up againt a strong wall and have someone look under the truck as you turn the wheel back and forth to see the worn part.
