I know we have had many of piston threads , but my main question is wether cutting is nec. or not ? i am going to build my motor this winter and i am not wanting to drop compression other than a grade "c" head gasket . My understanding on cutting pistons is it really helps to remove the ring on top of the piston because the extreme heat and cool down cycles makes that area of the piston weak and want to crack . With my truck i dont see egt's over 1150-1250 at the track and wonder if this still nec. My power goals with the truck are 700 hp . Sad part is i almost have the power i am wanting but i know the truck will not continue to take it . I dont want to put a roll bar in it so 11.49 is my ceeling for power/speed for now anyway . I know keying the cam and crank , rods ,head studs, machining ect are nec . , but dont really want to cut the pistons . If it came down to the fact that the pistons are to week un-cut i would rather run the new Mahle pistons . What are your thoughts ?
