Completey new here, just been reading posts as a non-member for a long time.
Anyone have experience or advice on how to get rings to seat? Really, really don't want to pull my engine back out and have the bores re-honed.
I just finished re-installing the engine in my truck. It cracked a piston at 405,000 miles, so I built it to handle more power with good longevity. I replaced the injectors at the same time as 4 of them tested bad after tearing everything down.
My break-in oil was Shell Rotella T4 15-40 with a ZDDP additive. I did not have new tuning upon initial start-up with the fresh engine and 45% over injectors, and it got probably 15 minutes of idle time right away, (broken into shorter segments.) I know this isn't ideal.
I then had to drive it for work, about 700 miles over the course of a week. During this time it developed an oil leak on the turbo, (missed torquing a drain tube bolt) and an up pipe leak. Both of these have been fixed, but it affected how I could drive. After almost 1,000 miles I finally got it tuned correctly.
All this while, I had massive blow-by out the crankcase vent. Enough to make one frame rail oily about 6' back from the hose.
After a lot of reading, I pulled the glow plugs and soaked the cylinders with penetrating oil overnight, then changed the oil to Rotella 10-30, and ran it really hard for awhile. I've put another 250 miles on it, and it still has tons of blowby. If I put my finger over the crankcase vent, it builds about 5 psi in short order, and starts pouring white smoke out the pipe.
Any ideas?? Did I glaze the cylinder walls? Am I screwed and need to start over? And what did I do wrong?
