Piston Poll:
Have you torn apart a race engine and seen piston damage?
  • Yes, ring land failure, 500-750HP
    Votes: 0 0.0%
  • Total voters
    62
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
For those running over 500rwhp, I'd like to get a feel for how many have had piston issues (under 500hp is probably factory defect), you can do multiple votes:
5,812
when i pulled my motor down to build it, i had piston #5 just starting to crack at the lip of the piston bowl. only piston that did it.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
No cracks. 500rwhp daily driven 156k on the clock. Quit racing many moons ago for fear of destruction.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Ran the stock LBZ with 30% tips and an S475 twin kit for years (74k mi), nothing but abuse (500+ passes, several hooks, few Dyno pulls, plenty of street fun) with no issues. Added a dual fueler for about a year on the same tune, never had any issues, and ran the same times in the 1/4. Decided I wanted to push it harder, and cracked #7 piston (94k mi). Still not sure what came first though, the crack or the tear drop blow torch hole through the piston and into the pin... The tops of all pistons were perfect and showed no erosion.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Corries orig stock engine ran at 680ish hp for a season of pulling and racing, #2 and #4 were starting to crack in the lips when tore down.
Current engine has stock delips about 80 hooks (2 seasons) at 900+hp, no issues yet,well be tore down over winter and well see how they took it!
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Race motor
Same piston since 2009. I have had the motor apart and just keep putting it back together with the same rings and bearings. This year I will put new rings. It's starting to get some blowby out the breather tank, not much but it never had any. If the bearings look good again they will go back in. This motor have been very good to me and owes me nothing.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
should add the tuner as well. Doesn't tuning play a big part in this?
Basically just looking at the percentage of those with aluminum pistons that haven't had problems at high HP.
Stock engines have cracked pistons with the factory tune. It's rare but just like broken cranks it's not impossible.
There are 2 basic camps. Those who say alum is working fine, and those who have had problems with it.
Knock on wood, our LBZ has about 75k miles on it, and hundreds of drag passes, heavy towing, dozens of dyno pulls, a handful of sled pulls, and even had some idiot thief fill the intake with water. Still no engine problems.
But if I had to rebuild "Wendy", I'd want something stronger than the LBZ pistons. Why? The set of pistons in Wendy now are "lucky", and the next set might be "unlucky".
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Looking at the poll results , Benny when were you at or over 750 RWHP ? I call BS ass -o- meters don't count! :D
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
Cracked 4 stock pistons. Cracked all 8 Mahle LB7 piston, which did not last longer than the stocks with 650hp
13,712
773
Cracked a stock piston in a totally stock motor with twins (maybe 650 HP). Also cracked a cut/coated LB7 piston in a built motor with big-ish twins and dual CP3s (somewhere around 850-900 HP).
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
What the heck are you doing? Holey crap! :eek:
Either you are the most unluckiest guy here or others aren't talking about their failures.
