LLY: PCV issue
valleyduramax
233
Ottawa ON Canada
I posted in a previous thread but no firm answers to my question so ill ask again.
The rubber diaphragms for the PCV check valves are rotten for lack of better description. I was informed that the only way to get replacements requires me to purchase the whole upper valve cover which i don't want to really do.
So I'm thinking about trying this. A check valve right after the outlet on the PCV casting and then gutting the actual PCV housing. The check valve would have a 0.5PSI or less activation and then this way it still retains some pressure while at the same time eliminating the diaphragm and internal spring and valve. I would just machine up some aluminum covers to replace the rotten factory steel pieces.
Would it work?????? Or would the check valve need a higher opening pressure? I have the All Season Diesel aluminum reroute fittings so would just have to buy a few -8AN fittings to accomplish this.
S Phinney
4,008
Quncy, Fl
I would say that using the reroute you would only need a check valve to keep some inse t or the likes from getting into the engine. Pressure shouldn't have to be muck at all.
valleyduramax
233
Ottawa ON Canada
Do i really even need the check valves? can i just gut the PCV valve on each valve cover and route the hoses into a catch can? Or are the check valves required for proper engine operation?
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
When using the pcv in stock form I believe the valve is there in case something catastrophic happens to keep debris and/or pressure from entering the valve cover. If you do something like what I have done which is route the pcv into the downpipe, the valve is needed in case of a nitrous backfire and to keep any exhaust gasses from entering, even though installed correctly it should create a vacume. I personally would not go with out a check valve.
As far as replacing the whole valve cover, that doesn't seem.quite right cuz it looks serviceable, but if its not I am sure there is someone here on the forum that has a set they would be willing to part with, if not there are some vendors like all seasons that sell used stuff regularly for good deals
Good luck man
