So basically I'm to the point in my swap that I'm wanting to fire the LLY engine. I had to build a harness to go between the engine and ECM. Everything is pinned out, powered, and grounded correctly to the best of my knowledge/ability. Hook up EFILive, click upload from PCM just to see what's on the ECM. It says PCM not detected, goes through 10 attempts before saying status unknown.
First thought is double check grounds but do any of the experts have any other places I should look? I bought the ECM used off here so I suppose there is a chance the ECM is bricked. I just wanted to make sure I checked all the easy stuff before sending it off to be checked. TIA.
