passenger windows wont roll down
workin' diesel
factory tuned
Nov 13, 2010
630
Coalhust, AB Canada
First pull your door panel off and see if you have any power at the switch. If you do, see if you have power at the connector for the window motor. I just replaced my passenger side window motor and track(comes all as one piece), this past summer. It was actually pretty easy to install. There is a fuse, but I am sure it is for both windows not just one.
RedHotGMC
stock
Jan 16, 2012
339
Northern Utah
Check the pdm fuse in the engine fuse block. Not sure if it controls both passenger doors but its worth a shot. Do your locks or keyfob work?
02ilduramax
632
3
fulton,illinois
Yup everything else works except those 2 windows I find it hard to believe that both window motors shit out at the same time but I guess anything is possible
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
checkpower to the window fuze,both sides,if power is there check driver side wireing harness by the door hinges underneath the rubber,wires constantly bending when opening and shutting the door will break the wireing inside.Also as stated before check the switches because if driver side switch goes out they run in circuit and will take both out.hope this helps.
