Help: Paint advice?
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
based on these specs for SEM Rust shield when should I apply my second and third coats? I am not using a hardener. would it be the tack free time or the re-coat time?
Typical Properties
W/O 38008 W/ 38008
Flash Time @ 70°F (21°C) & 50% RH​
3-5 minutes 5-10 minutes
Dust Free Time​
5-10 minutes 10-15 minutes
Tack Free Time​
30 minutes 1 hour
Tape Time​
3 days 12 hours
Recoat Time​
48 hours 6 hours
Cure Time To Put Into Service​
24-48 hours 24-48 hours
Total Cure Time​
7 days 7 days
Recommended DFT​
3 mils 3 mils​
BlkMax
743
Wasilla, AK
The recoat time is typically a maximum time that you can wait and still get a chemical bond with the first coat of paint. I would just use some good judgment based on how the paint is hardening....all of the recommendations from the manufacturer will change with air/surface/paint temperature and humidity. If it is not sticky on the tape that might be a good indicator for the next coat.
The time to recoat will also change based on how you are applying the paint: spray, brush/roller.
Good Luck.:thumb:
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
well I painted the control arms last night and this stuff is thick! I am using a brush. I had to go watch my brother's last bmx race so i wasnt able to recoat last night so i am going down to do it now. at 65* the paint was tack free in 30 minutes. I think i am only going to do 2 coats on everything, it isnt easy stuff to put on, thats for sure.
thanks for the advice BlkMax
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
here's some progress.....finally
here is a "before" image for comparison
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
after seeing how this cured in the last couple weeks, I am a little disappointed in its "durability" i expected it to resist scratching and chipping a lot more than it does. maybe it was because it was too cold in the shop (50-65) or maybe it just isnt that durable to impacts, but while putting the front end together i hit the paint with ratchets and wrenches and made a few dings right clean down to the primer. O well, I am not turning back now, hope it lasts with winter conditions:(
