Drivers side. I just used a 5lbs hammer on it with a piece of tube welded on the part of the shaft that is still sticking out. Slide bar hammer won't touch this thing. I shouldn't have installed the clip on the last rebuild. The clip is circular and the spline recess is cut square, its a stupid design. There won't be any clip put on it this time! Gonna have to pull the diff out. Split the case. Cut the rest of the shaft off. Pull the carrier out with the shaft still in it, pull the cross pin, beat the shaft out from the inside and rebuild it.
Sent from my PC36100 using Tapatalk 2
