Question: P2610
maxaholic
1,876
40
Central, Texas
What the hell does that code mean. Ignition off time data, is off the list that McRat made a sticky.
I think this is the second time that code has been thrown. Didn't set a CEL, I just happened to check codes for some reason and it was there.
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
It happens to me sometimes too , it pisses me off it usually only happens when I change tunes or I throw my hypertech on ( wich I sold ) but its wierd sometimes it happens when I take it back to stock and some times it happens when I change tunes and has some times been the culprit on the (CEL). When I had a BLY DOG Triple dog , I called the tech support and besides being a bunch of d%ckheads they said it was the ecm "knowing that it was programmed" I think it says ( internal engine timer malfunction) or some sh#t, I havent got a straight answer on this matter either and am damn curious.:mad:
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
What do you mean by that? I dont know what tuning the other gentleman is running but, I've had this code off and on again with all 3 tuners I have tried, the least trouble has been the PPE but it still happens from time to time when I change things.:confused:
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
Yeah I think it might be a blydog thing , the first tuner I used never gave that code and then I was talked into a triple dog wich ran ok but wasnt consistant and was a total pain in the ass to take off:mad:, I had to call blydog to get it cleared to go on another truck so I could sell it, and I've had this 2610 code sh*t every now and again since so I guess it happens with PPE too but I think blydog sucks thier tech support sucks, they are a dodge tuner as far as I'm concerned and they do ok there I guess, but with a d-max its PPE or EFI wich I would like to upgrade to. If you have an EFI live tune get the tuner and a comp and let these guy's show you how. If I was set up for it I would!:happy2:
Brian1
Jan 1, 2008
103
Just a DTC that pops up if a module is on for too long of period of time with igintion in the on position but not running. How long does bully dog take to tune?
Brian
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
Never actually timed it but I'm guessing about 20-30 minutes, for the triple dog anyway , it seemed like an f-ing eternity, but once loaded you could go from stage 1-3 on the fly as long as its plugged in. I get the code sometimes with my PPE sometimes too though but only when I go back to stock ( I have to do it twice to clear it all the way )What does the code actually mean?:confused:
Brian1
Jan 1, 2008
103
Whoa that long to tune. I can see why the code might pop up. I guess use to under 5 minutes for EFILive but that is partial flash. Not sure what full flash time is on EFILive.
Brian
