I just got my truck running after being wrecked in the front and it idles and cruises around pretty good, but at WOT feels slow to me. The dash does not show a code but I hooked my scanner up to it and it shows the desired rail pressure to be at 23k at wot and my actual is at around 10k. At idle and part throttle the values are fairly close untill you go WOT and the actual rail pressure starts dropping. Assuming this was a problem I changed the fuel filter and nothing changed. A friend recommended a balance test on the injectors and the worst one was -2 at idle and -2.9 in gear at idle.
I know quite a bit about cars, but nothing about diesels.
Since it is not getting the fuel pressure it is commanding I am assuming:
1. there is a restriction pre pump
2. the mechanical pump is weak(called cp3?)
3. there is something wrong with the regulator
There is no lift pump factory correct?
The only mod to the truck is a k and n air filter, and im not sure if it has a programmer from the previous owner, but seems unlikely. The exhaust at wot is just barely dark if you are looking in the passenger mirror for it. It is a 02 Silverado 2500 hd with 200k miles on it.
