nobody is gonna help?? Try posting a 4 digit "P" DTC, might get some help...
The Neens BFD Staff member Aug 10, 2006 4,596 1 36 Monrovia, Ca. Jun 15, 2009 #1 gdefranc said: nobody is gonna help?? Click to expand... Try posting a 4 digit "P" DTC, might get some help...
1lowdiesel <- wish i was there Sep 18, 2008 1,615 0 0 In Jun 15, 2009 #2 The Neens said: Try posting a 4 digit "P" DTC, might get some help... Click to expand... x2 need some more info. maybe like a p0088?
Fingers Village Idiot Vendor/Sponsor Apr 1, 2008 1,718 96 48 White Oak, PA Jun 15, 2009 #3 Check to see what your actual fuel rail pressure is. Both of these are the ECM complaining that the rail pressure is too high.
TrentNell Finally underway !!!!! Jul 7, 2008 7,543 0 0 44 slc tuah Jun 15, 2009 #4 might need to adjust the regulator current table( amperage ) it needs tweeking sometimes with a modded regulator .
1lowdiesel <- wish i was there Sep 18, 2008 1,615 0 0 In Jun 16, 2009 #5 also make sure the thing is plugged in all the way. if you clear the code then turn the key on, does it throw the code right away?
