2005 LLY. Has transgo kit.
Trying to figure out this p0840 code. Truck does not throw it when its empty and drives great. But once gooseneck is hooked to it, it throws the code and has shifting issues in the lower gears. Once it's in 4th and 5th it's fine.
It did this a couple months ago. I cleaned main plug and put electric grease on it. Fixed the issue tell now. Replaced internal harness and the pressure switch inside. Did not help.
