I bought a lbz with 100k miles with efi live, I set it on level 3 and had been driving the truck for a few weeks relatively hard, everything was fine shifts perfect. I got the transgo shift kit and installed it, performed a fast learn on the trans and had been driving it for about 30 minutes gradually increasing throttle, when I got to full throttle it threw a P0777 code which I understand is a tie up condition, I cleared the code and drove the truck for another 15 minutes before I decided to get after it again, this time ran threw all 6 gears foot to the floor with no problems (a bit clunky in higher gears) iam curious if this code can set if you are to hard on the trans in
the re learn? Or if I possibly could have gotten some contamination in the trans causing the solenoid to stick? Or should I just start saving for a build now?
