Allison 5sp: P0748 P0778 and no power in 1st gear
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Is it possible for these 2 codes to trip from low voltage during cranking? I'm getting my swap finished up and I'm getting these 2 codes but no check engine light from them. I've disconnected the connectors at the TCM and checked resistance and have 5.8 ohms on sol A and 6.0 ohms on sol B and no detectable shorts to ground or power. I'm currently only using 1 battery that has seen better days to run her as I my other group 78 won't fit now, I need a group 75 to clear the upper rad hose. I'm also having some other issues I believe are TCM related with no power in 1st gear only beyond 20% throttle. I've PM'd Brayden as he did my TCM for me, but the 2 codes have me scratching my head as to why they are popping up.
And they come up everytime during cranking. I can clear them and they won't return until I turn the engine over again.
15,681
These two codes will come up when the ignition is on and the main harness connecter at the trans is not connected.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I've cleared the codes since I had the trans unplugged. The resistance on the 2 solonoids is correct at the TCM connector and I can find no signs of a short in the harness. As for my low power in 1st I believe I have that one figured out as well. Seems 2 of my PENSACOLA remans are bad as the problem has gotten ALOT worse and does it in every gear now. followed by a raw diesel smell out the tailpipe with blue and white smoke now.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I ended up finally getting this all worked out and the SUB is up and running now. Ended up being bad injectors for the low power issue, and 2 new batteries took care of the 2 codes.
