Well figured it out. For anyone wondering, when the TCM loses that front sensor input signal, the TCM will use info from the ECM gathered rpm for turbine speed so it will still show turbine speed on a scanner. The real issue at hand was that alldata had the wire color and pin location at TCM backwards between the Turbine speed sensor and input shaft speed sensor. So we were ohming the input sensor from the TCM connector, which all checked out good. Once we figured out that info was wrong, found the correct pins at TCM, we had no continuity to the front sensor. Ended up being the pig tail at the turbine speed sensor was bad. Alot of headache for a $10 pigtail lol. Hope this helps someone in the future. Main thing is to me, it is dumb for live data in the TCM to be showing turbine speed when you have a fault code stating no signal, but it was using the ecm rpm to determine the turbine speed. Thanks for the help Mike
