Well I'm having a brain fart and can't remember how to read my allison fluid diagrams (doesn't help they are black and white).
2005 lly, stock air/ fuel/ trans 140k
Truck is throwing a p0716 code under heavy throttle from a stop. Will bang second and then limp.
Filters have been changed before I got the truck along with all the wiring checked and I believe they even put a tss on it.
I can slip the trans while in 5th locked and rolling into throttle on higher trans safe tunes. Holds fine in the lower settings in 5th.. 1-2 you can limp it on stock power.
Obviously needs a rebuild, just trying to figure out what clutch pack would cause both issues and learn a couple things.
apologies in advance on my stupidity and thanks for any information.
