I used this question on another forum without much luck. I installed a trans go Jr yesterday and when finished I got a p0700 code. I did a trans relearn and a u0101 came up. Used the edge evo cs to revert to stock as I hear that can cause issues and codes cleared but the p0700 came back. Before bolting the pan back on I checked everything several times. This is my second shift kit install and the first went without a hitch. Any ideas? I'll check the TCM connection and plugs when I get home. I don't believe voltage is a problem but I'll check the output of each battery. Will the evo pull TCM codes?
06 lbz edge evo, 5" straight pipe, egr block and finger stick, the usual stuff.
