Drove home last night about 100 miles and truck ran fine, started it up this morning and backed out of the garage. I had no throttle at all, smash the pedal to the floor and it doesn't do anything.
I have 2 codes
P0652 5-volt reference 2 circiut low voltage
P2228 Barometric Pressure Circuit Low.
I looked around and can't seem to find any broken wires. I found the the Baro sensor and it's wires are all good. could the sensor be bad?
If I use my Edge to monitor Accelerator Pedal Position while i have the codes I get 10% max
I did some googling and it says the p0652 circuit ties the a/c pressure, engine oil pressure and fuel rail pressure. I unplugged each corresponding sensor one at a time and restarted the truck. nothing seemed to make a difference.
When I unplug the Turbo Vane Sensor I get my pedal back and lose the P0652 & P2228, they are replaced with P2562 (Turbo Vane sensor)
If I monitor APP at this time it seems to respond as normal. the truck revs up good but obviously the vanes don't respond.
Could it be the Vane Sensor? it would be the second one to go on this truck. (second one is chinese)
I have 2 codes
