Emissions warranty yeah???
200,000 miles...
So how do we test them
test light on the glowplug
Glow plugs are the biggest cause of p0380's
Yep, You can go to the tip of each glow plug individually with a test light connected to 12volts, or pull the right and left outer most plugs on the glow plug module and test each circuit white wires are driver side and red wires are pass side. this is for california spec truck, You will have to check at each glow plug for 49 stater.
So it's not getting a MIL everytime. But it's hard to start in the mornin
Mil on and off is normal with a P0380. Just believe me...they do not fix themselves
Even with 3 plugs not working my truck never started hard in the morning...but I'm also not in an area that gets very cold.
I know enough about these trucks to know how MILs work. I do know that if that gpcm arcs it'll blow the 175A fuse and act similar to a bad plug or module. Chad thanks for the info I'm sure it's the same issue you had
