P0370- Timing reference signal A
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I can't figure this code out. I have no short in the ESS wire, CKP, and CMP wires all check out good. FICM wires are all well taped, connections aren't loose, I used dielectric grease on all the terminals. I DO NOT have the stock filter heater/filter head anymore, and the wiring was deleted from the engine harness. I have read that the ESS circuit should produce 4-5v and less than 10mA. I haven't checked that yet, but I plan to tomorrow. It tested good for no shorts and good continuity between the ECM pin and the FICM connector.
Any other ideas?
Also:
The reluctor wheel is an lly wheel, so that isn't it. if it's not in the wiring, it's got to be a sensor right?
