p0336
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
p0336
So here's my latest story with the truck:
The truck has had a rough idle for a while. Lately it had gotten worse. It would really shake the truck at idle and the balance rates were all over the place with two of the injectors over +14. Thursday morning as I got to work the truck died and wouldn't start. It would crank but nothing would happen. I got out my efilive and up came dtc p0336 which happens to be the crank position sensor. The Lab was generous enough to let me leave the truck there overnight so I caught a ride home and jumped on the computer to try to figure out what was really wrong and what I needed to do to fix it.
Sure enough, between this site, DP, and duramax forum I pieced together what I thought was wrong. A few buddies met me after work Friday with a trailer to drag it back to Sandwich.
The diagnosis was quick after I pulled out the crank sensor instead of the cam sensor. There is a reluctor wheel attached to the crank that has teeth on it that are seen by the crankshaft position sensor. Mine, which I found out is more common than I'd like to admit, was loose. Problem found.
The solution is to take everything off the front of the motor to get the front cover off. This took two of us about five hours as Ive never done this before. The local dealership had none of the parts needed but they did have a great diagram of how everything was situated in the motor. After many phone calls and sending two people two different ways, I got started taking the motor accessories off. All I really needed was a new crank seal, new bolts to put in the reluctor wheel, a new water pump as mine had 102,000 miles on it plus fresh coolant and oil.
We finally got the front cover off and put the bolts back in with red loctite this time cleaned the cover and put the whole thing back together. It went together much faster than it came apart and before I knew it we were firing it back up. The truck lit right up and idled smoother than it had in a long time. I did have two leaks. One fuel leak on the ficm where I forgot to tighten the banjo bolt and one coolant leak where we forgot to tighten two bolts on the water pump. both easy fixes.
Two days later, the truck is running great and idles smooth. It fires right up and I think the aircon is even cooler. I know this is long winded but I thought I would try to give back a little and maybe help someone else with this same problem.
mamu
162
arkansas
mine has been idling the same way and my injectors were up to a +10. then today going down the road it craped out on me. after trailering it to the shop i found my chopper wheel loose as well! will begin disassembly tomorrow!
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
This weekend we tore down another local truck with the same problem. they pulled the codes and it was the p0336. Pulled out the crank position sensor and the wheel was loose. Only took us 2 hours to tear it down, 2 hours to get parts and breakfast and 2 hours to put it back together and fire it up. It took about half the time it took to do mine. It's not too hard to do, now that I've done it!
Parts you'll need are a timing cover crank seal, 2 gallons anti freeze, 2.5 gallons of oil, new water pump, red loctite and gray rtv
Any questions, I'll be glad to help.
mamu
162
arkansas
i got mine all pulled down today. took me about 3 hours to pull all the radiator and charge air cooler. plus i pulled the lower oil pan to retrieve my other 2 bolts that were loose. but will get parts tomorrow and try to get my charge air cooler fixed. its got a little leak :D
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
we didn't pull the radiator or intercooler. We had plenty of room to get the front cover off. I left both missing bolts in the oil pan. we ran a magnet in the drain plug and nothing came up.
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
I tried to get the parts from the dealer but they needed about 2 weeks lead time. I needed my parts that day so they lost my business. I got the water pump anti freeze and rtv from napa. I had to call around all over and finally found a front crank seal at car quest. My buddy had the tool kits required to lock the flywheel and install the seal.
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
where did u get the new bolts for the reluctor? did napa have the pump in stock and do u remember how much it was?
bolts came from Ace hardware. pump was in stock and around 100 I believe. I didn't do much price checking, I just needed the truck running again.
