P0301 and high balance rate
thuddylikessmoke
Asphalt Cowboy
Aug 12, 2009
Fountain City, IN
Towing the 5er the other day got 45 minutes from home and truck started to run rough. Pulled over was knocking got a p0301 code and and injector 1 has no reading on the balance rate. Truck is back home now and i have been messing with it. Tried the ice pick on injector one didn’t seem to help any. I figured out if i tap the pedal and let it come back down it will show me a balance rate of +14.9 all others are around -4 to -6. Is it electrical? Should i try swapping out the injector see if it moves the balance rate with injector? What are the odds i got some shitty fuel? Or was there some contamination from all the work i had completed Truck recently had the Cp3 pump replaced, y bridge replaced, turbo apart to fix the vane plate and a few other things. Or did I crack a piston. Truck has ran great until this. 2004.5 LLY Dsp5 by Danville Wehrli Intake DHD Y bridge. EGR missing. Run a cat filter no lift pump.
