I finally solved all the oil leaks and got to actually run around with my new HTT installed. P0238 keeps getting thrown. I know it is because I am getting more boost than the 37psi that throws the code.
Can I simply change this DTC to "X: Not Reported" under Engine Diagnostics/DTC Test Enablers, and then under Engine Diagnostics/DTC MIL Enablers change it to "No MIL"?
This may sound a little simple, but I have never changed this type of parameter before, and want to make sure I am doing it correctly.
