P0103
FarmDiesel22
Farmer
Sep 28, 2009
128
The other day I started up my truck and it threw this code. P0103 mass or volume air flow circuit high input. I cleared the code and it comes right back when I start the truck up. I checked the connections and cleaned the maf sensor. Everything looks good and the code is still there. Any ideas on how to fix it? I am getting tried of seeing reduced engine power come up on the dash.
Canadian Cowboy
May 2, 2011
72
Detroit,MI-Windsor,ON
MAF Mass or volume air flow circuit high input Restriction, water intrusion, signal short to voltage, return circuit open, faulty sensor, faulty PCM.
It could be a broken sense element, test the MAF you need a frequency scale on a DVM multi-meter to check it.If you have a K&N on your truck get rid of it.
CC
