I need some input from you guy's on a P0093/P0102 code a friend is getting. I've done a bunch of research on this and I've come up with 3 causes. One was dry rotted fuel lines, and the other being the cp3. I've ruled out the FPR due to it being replaced. I wanted to see if anyone has had this issue and it turn out to be bad fuel lines.
I did a log of RP and the pump will make 23K for a short moment and then drop to 15K on a commanded 23K. This happens when the truck hit's OD and then it codes. Truck has no power adders at all..
Weak cp3?
Fuel filter has been changed, balance rates are great.
Edit: Also, is there a way to flush out a cp3 before you install it to make sure it's free of debri?
Weak cp3?
