Could this be why my truck is acting like a turd? CP3 take a poop? I will log it later 2nite when the girls go home:rofl:
i get that code on a regular basis, ive had it since my truck was stock it would come and go away with additive. and came back with my lift pump.
Im replacing my fca tomo to see if that helps out
Code:P0089Modules:ECM Description:Fuel Pressure Regulator Performance
It sure could. Either way tho it prob bad, so change it out and see what it does.
Ok, well, i had the LBZ cp3 on the way and it somehow fell out of the box on its way here...... I dunno if you saw the thread Oh, well. Ill pick another one up here soon. Im sure my cp3 is done for too. Can you explain how it would give me more lag and less boost if the fprv was faulty? Lose power? I still waxed some dodges 2nite:rofl: ill put the vids up.
That sux, I would go crazy if I got a empty box.
If the fuel is not at the correct pressure it wont atomize correctly and also you wont be getting the same amount per given PW. Fuel spools the turbo, to an extent....If I had to guess I would say this is your whole problem you have been having for a while, its just that it finally got bad enough to set a code.
This link might help you some.http://www.duramaxdiesels.com/forum/showthread.php?t=7307
Man im so close, i cant get the bottom bolt, my tx25 bit is too big
off to the parts store
so how about tuning this thing now what table was it exaclty needed to be changed?
ima play with it but if im stumped ima come back and check
