Today I shimmed my fprv and then drove to the hardware store to get fittings for my lift pump. All was good.
After I got the lift pump in it max's rail pressure to 26k. Turn the pump off rail is normal and no code. Everytime I turn the pump on I get the p0089 fuel pressure regulator 1 performance as the actual surpasses the desired.
I've never had this before and installed plenty of lift pumps. I don't think this can happen because of the pump pressure setting, and I've had them set higher in the past. Could it be the regulator is bad or a problem with the fprv?
