P0087 major problems
lucas6.6
Aug 20, 2014
99
Wisconsin Rapids, WI
Currently going down the highway, rail pressure is low enough that I can't maintain 55mph. At 50 mph rail pressure is 3kpsi. Bad fuel filter? Gelled fuel? It's -12 right now
lucas6.6
Aug 20, 2014
99
Im hoping that's the case. Stopped halfway home and poured a good amount of the power service diesel 911 additive in the tank to see if that would help at all. Any way to combat this? It's gonna be this cold for a few days and I'm planning on taking the truck up north this weekend. Also, will replacing fuel filter help?
LbzDMax07
179
PA
You're gonna have to replace the filter. It's probably waxed inside and I would just run a little extra additive. You should be good to go then.
lucas6.6
Aug 20, 2014
99
Changed the filter today, fuel that came out was a little thicker than normal. With the new filter it runs fine, I'm still seeing a loss of rail pressure at higher rpms in the higher gears, but I'd say that's because I don't have a lift pump
