would you like a timeout ... VVT's are for *****'s ha
I never did a relearn on my turbo when I replaced the sensor and also on a complete turbo swap. I read on a GM service document that after so many key cycles the vains will learn themselves. Worked for me.
Ya problem is I swapped in a known working VPS last night and problem still persists... Per an idea from a good buddy I changed the tune to command 90% vain position at all times and the vain % did not correlate. Under normal driving conditions VPS also does not follow the commanded parameters in the tune. This is a BD Quick spool or something modded VVT and the issues started right after install.
Maybe this will help:
http://www.duramaxdiesels.com/forum/showthread.php?t=33214
This one too:
http://www.duramaxdiesels.com/forum/showthread.php?t=33215
This may be a dead thread. Do I need something to view the links?
