Oversize Sac injector balance rates
LSxBakakos
101
22
Illinois
Tried searching, didn't end up seeing much to answer the question. over winter I ended up adding dual fuelers and a set of 65 over sac injectors. As some know I'm looking to lean hard on this stock bottom end. After a track day I decided to do a small health check because I'm paranoid.
I noticed in Park everything seems well balanced, under load I'm unsure if this is normal and I'm overthinking, or if I'm at the point where I need to run a compression test lol. My tuning goes to optimized stock unlike full stock like gm says per spec, didn't know if I'm worrying too early or with oversized sticks they're a little bit broader of a range of compensation
