So problem number 1 I rolled into the throttle on level 5 in 5th gear at about 60mph knowing it may cause problems and it did. Put the truck in limp mode and wouldn't shift into overdrive and the torque converter is slipping. Threw a check engine light and pulled a P0700 code through the Insight. After hooking up to a Solus, it pulls a 5th gear not in position. At this point I've lost 5th and reverse. However, after clearing the codes it drives ok til on the highway where it does the same thing after reaching overdrive. After checking the codes it comes up with a 0711 which is transmission temp sensor circuit failure. Any ideas? I thought it may a shift solenoid but could have smoked overdrive as well. Any other ideas?
