OUTVILLE ohio pull
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Yes Mitch that was Straley's
that things a animal....rumor has it its got 3 turbos:eek:....i couldnt see cause all the stuff under the hood....the coolest thing i sall was the injector lines going down through the middle of the valve covers. That thing ran for like 15 minutes before they pulled..... it was like 87* outside and it died on them......it wouldnt start back up without either:D
needless to say it runs like a mo fo
it still doesnt have anything for Clint Newmans black chevy gasser
that thing eats diesels and.......well you might say it poops fords:angel:
SmokeShow
6,818
Lawrenceburg, KY
I spoke with Straley at ORP (he is buddies with some friends of friends so we hung out Fri. night up there) and he DOES have triple turbos (off another mod truck that is now building an alcohol engine :eek: ) and you'd be surprised how low the crank HP is on that truck. He had it engine dynoed here in KY and its told that he has more power than Van and Curt Haisley and Scheid and its a great deal lower than I expected it to be. Think along the lines of what NastyGirl would probably ENGINE dyno and thats about right. ;)
C-ya
Mitch
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Rockwell axles.......stock chevy frame with solid suspension and no leafs
Hydrolic steering. Direct drive, and one big alcohol burning big block chevy built by him...i know is around 640ci give or take alittle. it should be right around 1200 horse maybe even alittle more.... needless to say it gets the job done....i think he pulled it 3-4 times that day
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
The only way that diesel truck will ever beat that black chevy is if
1 clint newman breaks
2 if straleys convert theres to alcohol.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Outville pull
Clint(black chevy) has a 632 with profiler heads and intake. The truck makes big power and is ultra smooth going down the track.I think eric and I were out of our class in a open single charger class! I was a few inches behind Eric again! I need to take the 100lbs weight out of my belly and hang on the front wieght bar!:rofl:
